Nitro sleeves + BFH = Successfully strengthening axles?
Old Dec 22, 2011 | 06:31 AM
AZJeeper's Avatar
Community Favorite
Default Nitro sleeves + BFH = Successfully strengthening axles?
This looks like a good opportunity to damage my elbow again:
http://www.truckaddons.com/jeep/Nitr...ar.htm#sleeves
I don't have rosette welding skills (actually, just about zero welding skills). Can't afford the labor to have someone do it for me. This just might be the ticket for an affordable reinforced front axle.
Has anybody any experience with beat-in sleeves? Is there a down side?
Old Dec 22, 2011 | 06:34 AM
scotty6336's Avatar
I've read a lot about them, here and elsewhere, IMO there just as good as the weld in sleeves. As I have read, just clean out the tubes real well and mabe take a grinder and just barely bevel the inserting edge of the tube a bit. I've also read freezing them before hand to shrink them down, which makes sence.
Old Dec 22, 2011 | 07:03 AM
D_engel's Avatar
these are definitely on my radar. Im just need to see a write up or tips on the install to ensure that everything goes in smoothly.
Old Dec 22, 2011 | 07:12 AM
Kmack84's Avatar
Hmmm Yea these just hit my radar too.. Still have to have a shop weld the C reinforcements on though
Old Dec 22, 2011 | 07:16 AM
JKred's Avatar
Agreed, freezing them will def help, unless you're installing them this time of year, then you're SOL...
Old Dec 22, 2011 | 07:53 AM
scotty6336's Avatar
Well IDK, it IS 70 here today
Old Dec 22, 2011 | 03:06 PM
highoctane's Avatar
Thinking of it as well. We have a -50 deg F freezer at work that we use to freeze spherical bearings for rotor heads before installing. These sleeves should slide right in at -50.
Old Dec 25, 2011 | 02:14 PM
D_engel's Avatar
so anyone have any experience with them?
Old Dec 25, 2011 | 02:19 PM
JC4me's Avatar
x2 anyone with experience??
Old Dec 26, 2011 | 12:49 PM
BuckLisa's Avatar
About to pull the plug on these; major labor savings; time and/or $$
