Question about spacer lift
Old Dec 24, 2011 | 12:45 PM
DKehler's Avatar
Default Question about spacer lift
I put on some 2" spacers and still have stock shocks and sway bar links (for now). Will this actually perform worse than stock? Could I possibly damage my shocks? (cause I don't have extensions?
Old Dec 24, 2011 | 02:43 PM
DKehler's Avatar
Bump for possible help from new viewers.
Old Dec 24, 2011 | 02:52 PM
glwood6's Avatar
you don't say how you are going to use your jk. That will determine what, if anything, could occur...
Old Dec 24, 2011 | 02:54 PM
phljeeper's Avatar
You should be fine with only 2". I would look to replace the front sway links with adjustable disconnects or longer links but you won't damage anything with only 2 inches.
Old Dec 24, 2011 | 03:00 PM
DKehler's Avatar
I don't want to get into any hairy rock crawlin, but would like to go wheelin in the desert which could get a little rocky. I probably will get longer sway links but in the meantime, do you foresee any possible damage with this setup?
Old Dec 24, 2011 | 03:09 PM
phljeeper's Avatar
No worries. I wheel my rubi with stock shocks and 2" spacer lift all the time. No damage and it clears my 34" tires great. Much improved wheeling over stock.
