Will the OEM spare holder, hold my 35??
Old Dec 26, 2011 | 07:02 PM
SRTLUVR's Avatar
Default Will the OEM spare holder, hold my 35??
Title says it. So will it?? I've heard it won't, and that in time, welds will start breaking? So with that being said, what spare tire holder do you guys recommend for a 17" wheel & 35" tire? THANKS all!
Old Dec 26, 2011 | 07:07 PM
Cdyspeed's Avatar
ive got the OR-Fab tire and gerry can holder and love it with that being said i ran my 35 on my stock carrier for a while some have problems and some don't
Old Dec 26, 2011 | 07:16 PM
_J__C_'s Avatar
35 should be fine for a while, maybe never have a problem.
But I really like my or fab and I'm glad I went that route.
Old Dec 26, 2011 | 07:18 PM
D_engel's Avatar
There are a lot of variables in play. Weight, wheel backspacing, how you drive your Jeep. Obviously, a heavy 35 is going to put a ton of strain on the door and it could start to sag or break welds. If you have wheels with low backspacing, the tire will stick out very far and you will need bump stop extensions to stop the tire rattle, not to mention it will have a leverage effect that will cause further problems. Of course, one of the largest factors is how you drive your Jeep. You could probably get away with a 35 on the stock carrier for a while if you take it easy and watch big bumps, but if you wheel hard, its going to expedite the breakage of spot welds and what not.
Old Dec 26, 2011 | 07:24 PM
SRTLUVR's Avatar
Thanks guys! The wheels I have, are 4.5 backspacing. The tire actually rubs on the OEM bumper a bit, which leads me to believe it "rests" on it to some extent, even if it's very minor support, I think it still may help a bit. I'm not a heavy off-roader by any means. I'm new to the JK community, and she only has 750 miles on her. So I should be okay for awhile. Just trying to do some preventive thinking/maintenance. I appreciate the help fellas, this is a new world for me, and just want to make the right choices.
