Transfer Case, I need 4:1 or lower
Any news on gears for the transfer case... i would like 4:1 or lower. I know teraflex makes kits for the TJ but is there anything out there or anything in the making.
Yea yea i know i would have a 4:1 if i bought the rubicon. just getn that out of the way
thanks
thanks
I think it is Mopar that mentioned they are going to sell a kit to regear or maybe even the whole transfer case.
EDIT: Once again I was too slow, not to mention I didn't post a picture of it! Damn Doojer, I think it was you last time too!
I know ive never done any extreme wheeling, I live on an island of sand.
and in sand, I dont even need low at all..
Ive tried low and its LOW..
Can someone help out an offroading amateur and give me a situation where 4.0:1 is that much better than the standard low (i think 2.7:1)
With lower gearing, you gain greater crawling capabilities, and are able to "walk" it over bigger rocks. Also, as Ctimrun said, your lower range makes for better engine braking - this is not only useful for hills, but for off-roading in general, because it makes your throttle inputs pack more punch (as you're effectively laying down more torque to each wheel). Make sense?
tshuelsman: Looks like you can pick up an Atlas 6.0 (6:1) for the tiny pricetag of $2635.00 (not including labor, axle mods, etc.). :sad:
Right on. Low is good for crawling over rocks - in 4LO at 2.72, my Sahara will happily walk itself over small rocks with ease, without my involvement (gas/brake). However, when it encounters a larger rock (greater resistance), the "walking" will stop, as the low range isn't sufficient to climb that bigger rock (in which case I just give 'er a little gas!).
i wish i had the money for the Atlas, i would love that option. and as far as buying a rubicon t-case. thats probally right around the same price range, buying from the dealer. But i don't think there would have to be as many mods, i should just bolt in.
i would like to just buy the gears and do the install myself.
