TF 2.5" BB + front adjustable track bar only
Next week going to install TF 2.5" BB, so my question is this: If i now also install front adjustable track bar and do nothing rear just keep original rear track bar there what are going to be consequences ? Should i also do something to my rear track bar or just drive it like this with adjustable front+original rear track bar.
I ordered this adjustable front track bar future lifts in mind.
I mean if i re-center my front axle only and leave rear axle a bit off-center what else i should do not to get any ESP issues, this being my main worry about. Anything else i should know and do ?
no. it's not needed but having one will allow you to recenter your axle. i personally do not like relocation brackets as a means to recenter your axle as more times than not, they over or under correct your axle shift depending on the make (how tall the bracket is) and the type of lift you have (how much lift you actually have). some relocation have multiple adjustments and they can be okay. the only time relocation brackets are really good to have is when you use it in conjunction to an adjustable track bar (and dropped pitman arm up front) and have them both installed on a 4" or taller lifted jeep. this will help correct your suspension geometry to where it needs to be.
Some customers that have the HD BB kits are adding them. But typically with the BB kits that have the spacers, it's not needed.
Thanks..
