anyone who has installed 2.5 TF BB
Old Nov 21, 2007 | 09:31 AM
davebloomer's Avatar
Default anyone who has installed 2.5 TF BB
how did you get your spacers to pop in place? i absolutly can't get them to go in???
Old Nov 21, 2007 | 09:32 AM
Rustler211's Avatar
Lube them up and a whole lotta elbow grease
Old Nov 21, 2007 | 09:36 AM
RotorHead's Avatar
You can also raise the axle with floor jack, but you should be able to pop them in if you lube them.
Old Nov 21, 2007 | 11:02 AM
bly109's Avatar
I stuck a brick on top of my axle and jacked them into place
Old Nov 21, 2007 | 11:09 AM
Anhedrew's Avatar
Lubed em up with white lithium grease and stuck a piece of 4x4 lumber between spacer and axle. Let off on the jack slowly and spacers will slide into place.
Old Nov 21, 2007 | 11:10 AM
BaltChief's Avatar
Are you talking the spacers or the bump stops? The spacers just sit above the springs, the bumpstops do need to be worked in like the others have said.
Old Nov 22, 2007 | 05:55 AM
matthew2000tx's Avatar
I'm installing this soon....
Old Nov 22, 2007 | 03:54 PM
AK4Dave's Avatar
I know I'm being cheap, but has anybody used the TF BB 2.5" with adaptors, and used your OEM shocks? If so, any problems, how do you like it?
Thanks....
Dave
Old Nov 22, 2007 | 04:31 PM
verbaltharhino's Avatar
Thanks....
Dave
No problems. I have "X" shocks on it and it's fine. I don't wheel as hard as some others on the site do, but light to moderate trails, they're good. I'll replace in the next year or so.
Old Nov 22, 2007 | 04:36 PM
doojer's Avatar
Thanks....
Dave
I've been running the Tera 2.5 with stock Rubi shocks and shock adapters for months and it rides just fine.
