Trektop as a winter top?? as well as....going rate for a used Hardtop???
I'm thinking of getting rid of the Hard Top for a Soft top. I like the Slant back look. I would need to sell the hard top as I don't really have a good storage place for it.
I've also have never owned a Softtop Wrangler, so it's all new to me. this is my first Wrangler, and it came with a Hard Top.
I am in MD, so we don't have horrible winters...infact it was almost 70 yesterday, lol. But I'm sure it will be in the Teens next week, lol.
How does the Trektop fair in the winter....and does it work well with the Tuffy Security Deck Enclosure?
Also..what is the going rate for a 07 Hard Top good shape, just paint chips etc.?
if your hard top is in really good condition, you can get rid of it in a hurry if you sell it for about $1000 or so.
regarding the trektop, if you get the new NX version, it will work out well for you as it has a lot more features that help it out in the weather better. it will also work with a tuffy deck although, i can sometimes be a bit tough to open and close especially in cold weather.
Sold ours in less than a week on Craigslist for $1000.
Although I have not installed my Tuffy security deck yet - I think I read something about there being an incompatibility with the Trektop NX rear door bracket or something along those lines?? If I remember correctly, the "fix" is buying an OEM version of the door bracket. I could be murdering the names here though.
I'm in the same boat as you though, considering letting the hardtop go. I have room to store it but could use the room for other things if I am not going to use the hardtop. Plenty of cold mornings here in Dallas (20-30) and I'm not having a problem keeping warm at all. No noticeable different from the hardtop really.
just came back to vent a little ...
had to unhook the rear tailgate bar and unzip a little to get something in the back yesterday; damned if I can get it zipped back up and closed again. it's been on all fall and winter so far but if you unzip it ones, it is impossible to get back without some sun and heat.
that is good I suppose, it is a tight fit and it makes it quieter and less leak prone - downside is that it is damn near unusable in the winter. I'm sure other have better luck with it.
Not sure how much money you want to spend on the top but I know wild boar makes a hard top version of the trek top called a fastback that's looks pretty good. I have the trektop but winter weather isn't an issue in Louisiana other than rain and I had more leaks with my factory top than my bestop trektop
I would like to try the NX trek top. I have the earlier model and with it being my only top it leaks at my drivers door and in the back. I would personally stick with the hardtop for the rest of winter.
The tailgate function is the same with teh trektop or the nx. it opens just like it does with your OEM tops. the NX has removable side pieces and is not as tight as the original trektop. I have no issues with my trektop with zipping the rear window or leaking. I actually used my trektop more than my OEM soft top. Just my $0.02
My trektop NX does not leak at all. I love it! The leaking you have could be that the drivers door is not aligned properly. I only know this because I had the same issue when I removed my hinges to bedline them. Came up with a leak at my front driver door and on the back driver side....realigned the front driver door and everything is great.
