Rock Krawler 2.5" Max Travel Bumpstops
Old Jan 9, 2012 | 04:26 AM
Ringer's Avatar
Default Rock Krawler 2.5" Max Travel Bumpstops
I have a 2 door with the 2.5" max travel kit. I am planning on running 35's. What are you running for bumpstops with this setup? Also, I eventually plan on going with flat fenders, so would extended bump stops even be necessary?
Old Jan 9, 2012 | 04:37 AM
tslewisz's Avatar
Yes, you need the stops to keep the shocks from bottoming. I have 35's and flatties and I run 1" in front and 2.25" in back. You can probably get away with a little shorter extensions in the rear, but I have EVO Rockstars so the bottom mount is moved up.
