Rotional clicking noise: not driveshaft boot
Just recently a clicking noise has developed. I have an auto tranny. The sounds occurs is park while revving engine and also while driving, mostly in 1st, 2nd and 3rd gear with 2nd being the most noticeable.
Climbing under the JKU the sounds seems to be coming from inside the transmission housing where it meets the engine.
Any ideas what this would be? I'm guessing my factor warranty won't be valid due to my mods.
Also I noticed a very small amount of grease or lube where the front DS meets the pumpkin...thoughts?
I had the same noise and it turned out to be my rear ds. After market d shafts? The grease on the pumpkin sounds like the flanged isn't torqued down all the way. This will also cause vibration when accelerating, (or decelling if it is the rear pumpkin) because you are actually pulling on the f/ds flange, causing it to come out of the pumpkin and wobble. I'm no mechanic though, but you might want to start there, its easy enough to diagnose.
Chad
Chad
Chad
Chad
The thing that I dont get and makes me think it's npt the DS is it makes the noise while in park revving the engine. I have factory DS still.
It does not make the clicking sound while in reverse.
I have zero vibration while driving.
Also it is not constant.
It mainly occurs while accelerating from a stop or near stop in the 5-30mph range then it stops the clicking...it really almost sounds like a when u stick a card into a fan just a little more metallic in the click.
It does not occur over 40mph.
Originally Posted by Jkrgv
I had a k&n air filter rattle against the radiator support, check that if you have one
In my amateur thoughts it would seem to be something like a torque conveter or flywheel maybe??
Remember on forward accel, the power train and the body flex change angles from forward to reverse! Check if getting a rattle from something hitting cause of changes in clearance
Originally Posted by SolarJKStar
Thanks for the thoughts.
yea, but you were saying you had some oil coming out of the seal on the pumpkin. Mine as well check it out, gotta look at that oil leak anyway. just saying
I did another quick test, I revved upmthe engine slighty till the noise was occurring, shifted into R and it instantly stopped.
It occurs in both 2 & 4wd.
