35x12.50 on the spare tire mount
Old Nov 24, 2007 | 01:40 PM
zerodown's Avatar
Default 35x12.50 on the spare tire mount
Hey everybody. I'm Larry. I just traded my 06 rubicon in for an 08 JK. I have already ordered up a 3" TF lift, and some 35's.
My question is, and I apologize if it's been covered, will a 35X12.50 on the stock 17 fit on the spare tire mount? Thanks in advance.
Old Nov 24, 2007 | 01:57 PM
mkjeep's Avatar
IT will if you put a 1.5 in spacer or cut the rubber mounts on your tailgate. Lota weight on the gate though. Best to do a third brake light mod too.
Old Nov 24, 2007 | 04:25 PM
GadgetFreek's Avatar
Ditto. Will not fit without a spacer. I tried taking the rubber spacers off but it was still too close on the stock bumper. It would have put things in a bind and that is a whole lotta weight on the tailgate.
Old Nov 24, 2007 | 05:43 PM
JK07's Avatar
I am going from 33 MTZ to 35 MTZ on a stock spare tyre mount. I will be fitting the 35" spare without any air in it to decrase the weight. As I have a dual ARB air compressor onboard which i will use for putting the air. But currently i have noticed my stock rubber gourmets have a gap between the tyre.
Old Nov 24, 2007 | 10:01 PM
matthew2000tx's Avatar
Originally Posted by Zak
...I will be fitting the 35" spare without any air in it to decrase the weight. ...
How much does air weigh?
Old Nov 24, 2007 | 10:07 PM
Ctimrun's Avatar
I run 28 pounds of air in mine....
Old Nov 24, 2007 | 10:08 PM
dr.dirty's Avatar
is that summer or winter air
Old Nov 24, 2007 | 10:29 PM
CIJeep's Avatar
Old Nov 25, 2007 | 06:18 AM
kntr's Avatar
Guys around here run 37s on the spare with a spacer. Not me though, too much weight.
Old Nov 25, 2007 | 06:29 AM
armycop's Avatar
At standard temp and pressure .0807 lbs per cubic foot.
