Tuffy Tailgate Security Enclosure for 2011- - ->
Old Jan 10, 2012 | 04:52 AM
MikekiM's Avatar
Default Tuffy Tailgate Security Enclosure for 2011- - ->
Anyone using it?
Interested in fit, security level, compatibility with soft & hard tops...
Old Jan 10, 2012 | 05:35 AM
greggnj's Avatar
Tuffy has a different part number for 2011-2012 (275)
look here: http://www.northridge4x4.com/proddet...prod=TUFFY-275 I'd guess that Quadratec carries it as well but not sure...
It's at the top of my mod list...before I put the soft top back on. Not cheap but I think it will be well woth it to have all that lockable space.
Old Jan 10, 2012 | 06:00 AM
tuffy2's Avatar
Sponsoring Manufacturer
Actually, the #275-01 2011-2012 Deck Enclosure is a full sized enclosure. The 2011-2012 Tailgate Enclosure is designed to leave the back seat in in a 2 door and is Tuffy's part #282-01. This secures the area behind the 2-door's back seat and works with the tailgate.
For 2007-2010 JK's - #286-01
For 2011-2012 JK's - #282-01
Since these are smaller versions of our Security Deck Enclosure, the price is more budget-minded as well. You're right...Northridge and Quadratec stock our full line of items, so give them a yell and see if they can help get you locked up!
Old Jan 10, 2012 | 06:01 AM
wayoflife's Avatar
JK-Forum Founder
chris from full-traction suspension has one installed in his 2012 and it's the same thing as the 11. it's real nice and very secure. i just got one for our 2012.
Old Jan 10, 2012 | 06:03 AM
tuffy2's Avatar
I can't believe I said, "Give them a yell" How old-school is that?!?!
Old Jan 10, 2012 | 07:13 AM
Moochie's Avatar
Originally Posted by zmotorsports
Holy cow. You have a 2012 now too? I must say I have enjoyed reading your threads/responses and have also enjoyed watching some of your videos on youtube.
What are you doing to the 2012? Is this going to be yours/wife's daily driver or a trail rig only?
Mike.
FYI:
https://www.jk-forum.com/forums/show...hlight=rubicat
Old Jan 10, 2012 | 08:01 AM
Full-Traction Suspension's Avatar
Former Member
Yep. I'm very happy with it. Nice quality, great fit and its Made in the USA
Just mounted my ARB frig on it this weekend
ID:	262201   Click image for larger version
Old Jan 10, 2012 | 08:06 AM
MikekiM's Avatar
Which one is that? The Deck Enclosure or the Tailgate Enclosure?
Old Jan 10, 2012 | 08:24 AM
Former Member
"the #275-01 2011-2012 Deck Enclosure is a full sized enclosure"
Covers from the back seat to the tailgate
Old Jan 10, 2012 | 08:25 AM
GunDude's Avatar
I had the Tuffy Security deck encloser in my 11' and took it out when I put the hard top back on. I have a few issues with it. First, it comes with standard 1/2 bolts and nuts and not security bolts! This goes with, at least on the security deck, there is only one bolt on each side holding it in, they bolt into one of the hard top bolt holes on each side, unless you want to drill two more holes in your fender well.
You also have to take it apart to change from hard to to soft top. I added security bolts and made to brackets that keep the front locked down to the rear seat brackets.
I think, I will be cutting mine down to the width of the rear tail gate and welding on some side, and make brackets that use the rear seat brackets and tie down loops.
ID:	262216   Click image for larger version
ID:	262217   Click image for larger version
ID:	262218   Click image for larger version
