Need Bumpstop advice for my Rock Krawler lift!!!
Old Jan 10, 2012 | 05:46 PM
FlameRedJK's Avatar
Default Need Bumpstop advice for my Rock Krawler lift!!!
I'm buying the Rock Krawler 3.5" Triple Threat Long Arm kit this week and need advice for what bumpstop to get and what size.
Thanks!!
Old Jan 10, 2012 | 05:57 PM
superjk10's Avatar
X2 in getting the x factor 5.5 With 3.5 coils
Old Jan 10, 2012 | 07:00 PM
nachorubicon's Avatar
Originally Posted by 2008fx4
i basically have the 3.5 midarm flex and im running teraflex speedbumps
what size bump stops?
Old Jan 10, 2012 | 07:12 PM
Biggy's Avatar
It would help if we knew your tire size and kind of flares you will be running.
Old Jan 10, 2012 | 07:23 PM
FlameRedJK's Avatar
Default tires and flares
I will be running 35" tires and stock flares until i can afford to go flat
Old Jan 10, 2012 | 07:47 PM
Biggy's Avatar
Originally Posted by rustyshackleford
I say go flex it and.measure how much you would need before rubbing..
Ya thats what I did and is the best way to determine the proper length. With 37x13.5 tires with flatties I ended up being 2" in the front and 3" in the back. I could probably knock a 1/2 off each and still be good.
Old Jan 10, 2012 | 07:50 PM
Biggy's Avatar
I would PM the RK rep on the forum. He should be able to help. If I had to guess I would say 2 in the front and 3 out back with stock flares and 35".
Old Jan 10, 2012 | 07:59 PM
sip8137's Avatar
I was told by there rep that for every inch you go up you need to match it with the size of the bump stop!! Example you lift it three inches your bump stop should be three inches!! I've got a 3.5 mid arm x factor when I called teraflex I was told that two inches should be more than enough!! I went however with 2.5 inch bumpstops
