Anyone change 2012 muffler?
its friggin LOUD but sounds a lot better with resonator off vs just muffler. I'm going to straight pipe it for a few days but will most likely throw a flowmaster 40 on there. I would highly recommend removing the resonator if you throw an aftermarket on tho. I think would eliminate a lot of rice sound. Sounds OK with just muffler off, but a lot deeper sound with both off. Just really loud lol
Originally Posted by Black_JKU
Just checking to see if anyone has gone to aftermarket mufflers yet?
If so:
Thoughts?
Sound?
Would you do it again?
Ect......
If so:
Thoughts?
Sound?
Ect......
Originally Posted by kh202
I recently took off the stock muffler AND the resonator...
) But for some reason the bolt was a bitch to break lose (only a month and a half old), so i'd recommend throwing some WD on before you do it and let it soak in awhile. But its same concept as taking the muffler off, one bolt and 2 rubber hangers and it slides out in one piece. Took me longer to do it but i think it was worth it. Right now, yes it dumps out right under my seat where the loops make a Y. There is a weird buzzing sound when I let off gas around 1000-1500 rpm, but I'm running a straight pipe and 45 deg bend back later today, so that should get rid of that. Most likely will bolt a flowmaster on there. Should smooth out the tone a little and mellow it out a little
HEre is mine with no resonator and a flowmaster super 44
Wide open 2012 wrangler flowmaster super 44 - YouTube
Normal acceleration to 60 ish 2012 wrangler super 44 - YouTube
12 JK 3.6 Pentastar
Removed stock muffler and replaced stock resonator with a flowmaster 10. Does not sound overbearing at all or yet--sounding like a Mustang or Camaro. Just a deep throaty/growling tone.
Subtle take-off:
2012 Jeep Wrangler Exhaust - YouTube
Driving around the block:
Subtle take-off:
Originally Posted by Torancis_Jeep
12 JK 3.6 Pentastar
Subtle take-off:
Subtle take-off:
Where does your exhaust dump, right behind axle or did you extend it out the back
Exhaust was extended to the back.
