2011 JK - At what point would I need extended brake lines?
Old Jan 11, 2012 | 02:06 PM
jckid's Avatar
Default 2011 JK - At what point would I need extended brake lines?
I have an '11 Rubi with a Teraflex Leveling Kit, except that I opted to only go 1.5" in the front rather than the ususal 2". I am thinking about replacing my stock Rubi shocks with new ones that are 1" longer when extended. Since my JK is a 2011, it has the new style front brake lines/brackets. Can I install these 1" longer shocks without issue, or would I need to extend the brake lines and/or remove the bracket?
Old Jan 11, 2012 | 02:19 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Fronts are fine, with a little work to the stock brake line brackets you can use them even with a 6" kit. With the rears, TeraFlex uses drop brackets for the 2.5" and 3" kits.
Old Jan 11, 2012 | 02:21 PM
Jfh1976's Avatar
I installed the TerraFlex 2.5 BB on mine. I did not have to replace the brake lines, but the kit included a bracket to drop the line an inch or so. When I was installing the lift, the suspension flexed way beyond the length of the stock shocks, and the brake lines worried me a bit. I think that anything more than 2.5 would require the brake lines to either be extended or modified in some other way, like a moderate bend up line. I'm new to this so don't take my word as gospel, only my two cents. Hope it's helpful.
Old Jan 11, 2012 | 02:28 PM
jckid's Avatar
Wow! Thanks for the quick reply. The rear shocks are also almost an inch longer when extended. So would they be ok as well? I didn't really even think about the rear brake lines. But if I understand your post correctly, the rear's wouldn't be an issue until 2.5".
