Yes ANOTHER noob tire and lift question
Actually it's two questions, I have a 1" leveling kit and a 1.25" body lift. I was wondering if I could run 35" tires and if I could also run them on my factory 17" wheels.... Thanks in advance!!
You can put 35's on the stock wheel but you will probably need wheel spacers to get the backspacing right. I put 34's on with 2.5" lift and 4.75" backspacing and the rub just a little on full lock but only in reverse.
