Poison Spyder Lower A-Pillar Light Mounts
The Poison Spyder JK Lower A-Pillar Light Mounts provide a convenient way to mount a pair of off-road lights on to the lower A-Pillar area of the Jeep JK. Designed specifically to fit the Rigid Industries Dually or Dually D2 LED lights, they may also fit other brands of compact off-road lights (the light mounting hole is 7/16"). The brackets are CNC laser cut and brake-formed steel, powder coated semi-gloss black. They are sold in pairs and include rubber liners to protect the Jeep's paint. These mounts CAN be used together with our A-Pillar 50" LED Light Bar Mounts. And we provide the longer hardware you'll need for this setup!
When you buy a pair of Rigid Dually D2's directly from Poison Spyder, we'll throw in a pair of the Lower A-Pillar Light Mounts for FREE, if you choose the Dually D2/Lower A-Pillar Mounts Bundle!
You can re-use your stock black screws if you're running these mounts by themselves. We only provide the ones in the kit in case you're "stacking" them with our A-Pillar 50" Light Bar Mount. In that case the stock ones are a little too short so we provide the ones in the kit, which are a little longer. The button head cap screws we provide are stainless steel for corrosion and rust resistance. The commonly available black oxide fasteners rust too quickly, and there is no other cost-effective option for a corrosion resistant black fastener. If you stack both brackets and need a longer fastener, but prefer it to be black, we suggest painting the heads of the ones we provide. If you still want a black oxide bolt, you can get them from any decent hardware store or online from mcmaster-carr. The size you'll need is M8-1.25 X 35. But be aware they won't be black for long, they will become a dull orange fairly quickly.
"Finally got to install my lights and light mounts. Can’t tell you how much I love the look and the installation couldn’t have been any easier. We will definitely be buying more Poison Spyder products in the future."
Audra used our TJ Lower A-Pillar Light Mounts. They are also available for the JK. They come powder coated black, with stainless hardware and rubber gaskets, for only $29. Or you can get them for FREE when you purchase a pair of Rigid Industries Dually D2 LED lights (click for TJ or JK)!
-Audra Martz
Thanks for the kind words and photos Audra!
