Windshield Lights
Old Nov 26, 2007 | 11:31 AM
xoxoJeepGalxoxo's Avatar
Default Windshield Lights
Bare with me... I don't know what I am talking about...
I want to get some windshield lights like some KC's... but I don't know which ones to get, is there a kit?
I want something pretty easy, fairly cheap, I don't need the lights to be super bright or strong, just some extra light would be nice...
Suggestions???
Old Nov 26, 2007 | 02:17 PM
Originally Posted by N2rock
First decision is which bracket to use for mounting. Mopar's bracket is the most expensive ($80+), whereas the KC and Rugged Ridge brackets run under $30. The biggest difference is that the Mopar brackets place the lights more outwards, whereas the lesser expensive ones are not out, and are mounted higher. Personally I prefer the outward look over the others. But that is just each person's own taste.
Lights- many lights and sizes to chose from. KC Slimlights seem to be the most popular. They are 6" lights- you can either buy them individually, or as a kit- best to just get the kit as it contains all the wiring harness, relay, switch, etc..
here's the kit - http://www.quadratec.com/products/97048_20.htm
There are many other companies making lights though. KC just seems to be the most popular. But shop around and you may decide on another brand. Also look at member pictures to see differences in the size. I personally prefer 8" look over the 6". But 8" is quite a bit more expensive.
Here's some picture of Clackey's rig with 6" and then again with 8" (his pictures are what sold me on going with 8" - which I haven't done yet due to cost)
Here's his ride with the 6"
http://my.project-jk.com/showphoto.p...=739&ppuser=72
And here's the 8"
http://my.project-jk.com/showphoto.p...3264&ppuser=72
Also note that he is using the Mopar brackets. The Mopar brackets are probably a necessity for the 8" lights because they move the lights outwards far enough to not be an obstruction. The KC & Rogged Ridge brackets may have the larger lights moved to far inside and be an obstruction to your view.
Thank you so much that is a big help!
Old Nov 26, 2007 | 03:43 PM
floridamud's Avatar
I have the KC Slimline lights and they work great, easy to install, and cheap, If you want them off road get the long range
Old Nov 26, 2007 | 04:28 PM
JimmyDutch's Avatar
Originally Posted by Grant211
What am i? Chop liver?
just kidding
Thank-you for her, now pass the onions...
Old Nov 26, 2007 | 06:55 PM
CLACKEY(_!_)'s Avatar
Suggestions???
I don't think I can add anything that hasn't already been said. however this does give me an opportunity to post more pics of my Jeep. I'm such a whore
Old Nov 27, 2007 | 11:58 AM
westchester's Avatar
Suggestions???
Enjoy putting them on....many of us with them have posted tips to wire and mount them on these threads.
Mopar light brackets https://www.jk-forum.com/forums/modified-jk-tech-2/mopar-light-brackets-19917/
Windshield lights - Show me what you got https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/windshield-lights-show-me-what-you-got-14166/
Kc daylighterss on windshield mounts https://www.jk-forum.com/forums/modified-jk-tech-2/kc-daylighters-windshield-mounts-17332/
Old Nov 27, 2007 | 06:11 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Suggestions???
hey Country girl....shouldnt your Christmas Boyfriend be getting lights for you already?
Old Nov 27, 2007 | 07:53 PM
What? It's not enough that I used your name and posted your pictures already?
It's never enough!!!!
Old Nov 28, 2007 | 12:07 AM
JKFirefighter's Avatar
Go with the Mopar brakets, the lights end up in a better spot - wider and lower. I put the PIAA 525's on my jeep, and the wiring was easy, relays and fuses are all pre-assembled. And the lights work great.
Old Nov 28, 2007 | 08:22 AM
rogu3JK's Avatar
Anyone know if the River Raider Snorkel works with the Mopar light bracket?
I see Slick Will has some lights and the snorkel but Im not sure if its the mopar bracket being used.
