Do I have the tow package?
Old Jan 30, 2012 | 05:46 PM
bluballz83's Avatar
Default Do I have the tow package?
Hope this is the right spot for this post. I'm trying to figure out what my gear ratio on my front axle is, I read if I have the tow package it's 4.10. Below is my build sheet, can anyone tell me what my ratio is?
Vehicle Description JEEP WRANGLER UNLIMITED X 4X4 SPORT UTILITY 4-DOOR
Model Year 2007
Body Model JK J M 74
MSRP $26,175.00
Sales Code Description
*A7 Cloth Low-Back Bucket Seats
-DD Dk Slate Gray/Med Slate Gray
APAS Monotone Paint
BABS 160 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BNMP Traction Control
BNSP Electronic Roll Mitigation
BPTP Hydraulic Assist Brake Booster
BRWS 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CDBS Reclining Front Seats
CDHP Driver Height Adjuster Seat
CFNS Rear 60/40 Folding Seat
CGWS Next Generation Front Air Bags**
CGXS RR Head Restraints Outboard Seating
CKES Front Seat Area Carpet
CKFP Rear Seat/Wheelhouse/Cargo Carpet
CLMS Sport Bar w/Full Padding
CUFS Full Length Floor Console
CURS Rear Compartment Storage Tray
DGBS All 4-Speed Automatic Transmissions
DGV 4-Spd. Automatic VLP 42RLE Trans
DHES Man Shift-on-the-Fly Transfer Case
DJRS Next Gen. Dana 30 Solid Front Axle
DMFP 4.10 Rear Axle Ratio
DRZS Next Gen. Dana 44 HD Rear Axle
DS7S Conventional Differential Frt Axle
DS8S Conventional Differential Rear Axle
EGT 3.8L V6 SMPI Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GCDP Deep Tint Sunscreen Windows
GCFS Full Metal Doors w/Roll-up Windows
GFAP Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNYS Passenger Side Sun Visor
GTVS Swing-Away Mirrors
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
JAYS Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JE8S Manual Door Locks
JFJP Temperature & Compass Gauge
JF8S Manual Windows
JHAS Var Intermittent Windshield Wipers
JHBP Rear Window Wiper/Washer
JJFS Single Low Note Horn
JJJS 12V Auxiliary Power Outlet
JKAS Locking Glove Box
KDSS STRIPE/BADGE/MOLDING/COLOR
KESS STRIPE/BADGE/MOLDING/COLOR
K3XS STRIPE/BADGE/MOLDING/COLOR
LHES Rear Dome w/On/Off Switch Lamp
LMAS Halogen Headlamps
LNJP Fog Lamps
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MB5S Black Rear Bumper
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MT2S Trail Rated Badge
MVCS Jeep Badge
NAA Federal Emissions
NF5S 23 Gallon Fuel Tank
NHMP Speed Control
PR4A Flame Red Clear Coat
QR4S Flame Red Clear Coat
RCGS 6 Speakers
RDDS Fixed Long Mast Antenna
RESS Media Center 130 CD/MP3
SBAS Power Rack and Pinion Steering
SCLP Leather Wrapped Steering Wheel
SDUP Heavy Duty Suspension w/Gas Shocks
SHAS Front Stabilizer Bar
SHCS Front and Rear Stabilizer Bars
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TUFP P255/75R17 OWL On/Off Road Tires
TZAP Goodyear Brand Tires
VKXA Black Hard Top
WFF 17X8.0 Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XCAS Occupant Classification System
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XEWP 2 Front & 1 Rear Tow Hooks
XE9P Transmission Skid Plate
XJFS Tethered Fuel Filler Cap
XJGS Non Locking Fuel Filler Cap
XPFS Protective Coating and Remover
X81S Instrument Panel Parts Module
X83S Front End Parts Module
X86S Complete Chassis Parts Module
X88S Tire & Wheel Parts Module
X92S Complete Body in White Parts Module
X94S Complete Painted Body Module
YAAS Build To U.S. Mkt. Specifications
Old Jan 30, 2012 | 05:56 PM
StuFarmer's Avatar
Your Build Code DMFP states you have 4:10's. Your front & rear ratios are always the same.
Old Jan 30, 2012 | 05:59 PM
ronjenx's Avatar
The fact it has an automatic means it would have come with 4.10 gears.
Old Jan 30, 2012 | 06:06 PM
BrowniesJK's Avatar
4.10's. Says that's what is in your front and both axles have to match. If you have a tranny cooler and hitch its safe to say you have the towing package.
Old Jan 30, 2012 | 06:19 PM
bluballz83's Avatar
Great. Thanks for the quick replies. I'm a noob so didn't know both axles were the same.
When I go to 35's will I be good with this ratio then?
Old Jan 30, 2012 | 07:54 PM
dan3jeeps's Avatar
All depends on what type of wheeling you are doing with those 35's. Some here seem to think that combo is OK, some regear.
Street driving, dirt roads, easy mountain trails, even moderate mountain trails... you'll probably be OK with that combo.
You may have to put the auto tranny in 3rd if you are driving a lot of hills and the tranny keeps shifting back and forth.
Same with towing... lock out OD.
Hard core trails and rock crawling... better regear to 4.88's or lower and install a locker too.
Good luck and have fun!
