Will this fit my JK?
Hi,
I have 5 American Racing w/BFG A/T from my TJ. This is the link for the rims.
http://www.quadratec.com/products/92800_2XX_B_PG.htm
It's part# 92800.201
Bolt Pattern: 5x4.5
Backspacing: 3 3/4
Tires are 33x12.5
If I bought the TeraFlex 1" Wheel Adapter (link: http://www.quadratec.com/products/92807_201.htm ) does anyone know if they would fit on my JK. It's a 4dr, Manual Sahara and it currently has the Stock 18" rims. Would it clear all the brake lines, rub, etc?
Thanks.
Bolt Pattern: 5x4.5
Backspacing: 3 3/4
Tires are 33x12.5
Thanks.
Hi,
Bolt Pattern: 5x4.5
Backspacing: 3 3/4
Tires are 33x12.5
Thanks.
Bolt Pattern: 5x4.5
Backspacing: 3 3/4
Tires are 33x12.5
Thanks.
Realize that this will put some stress on your bearings, knuckles, etc...
If I were you, I would reconsider and go with some 5x5 wheels to get rid of the adapter/spacer. Sell your TJ rims and use the money to offset the cost of new rims.
I'm glad you noticed that too!
NO, they will NOT fit! The TJ used 5x4.5, but the JK uses 5x5. You would need spacer adapters (to convert 5x4.5 to 5x5 B.P.) to mount TJ wheels on your JK.
Hi,
Bolt Pattern: 5x4.5
Backspacing: 3 3/4
Tires are 33x12.5
Thanks.
Bolt Pattern: 5x4.5
Backspacing: 3 3/4
Tires are 33x12.5
Thanks.
I think he knows what the bolt pattern is. Look carefully "If I bought the TeraFlex 1" Wheel Adapter".
I think the other guys are right though. Look into a new set of wheels. That backspacing plus another 1" with the adapters might be too much.
