Fitfing 33's with no lift
Old Feb 7, 2012 | 12:12 PM
JK.NZ's Avatar
Default Fitfing 33's with no lift
I have a 2010 Rubicon and want to fit 33's to stock Rubicon wheels with no lift. From reading other posts I will need spacers 1.25" or 1.5". Will I get rubbing without a lift? Are there any other problems that I might encounter?
Old Feb 7, 2012 | 12:15 PM
FoxRacingJMC's Avatar
If you are keeping stock wheels, then yes - you need spacers. If you are getting new wheels, I'd say you need at least 4.75" backspacing or less to not rub. Other than that, you shouldn't rub anything....
Old Feb 7, 2012 | 06:29 PM
1978cj7jk2012's Avatar
I had slight rubbing with my 33 12.5 on my 2012 2 door with aftermarket wheels but nothing major. Just rubbed the flares and the stock bumper skid. Got new bumpers and trimmed flares and bang! Problem solved.
ID:	275554   Click image for larger version
Old Feb 7, 2012 | 07:42 PM
CerOf's Avatar
You will rub with stock or only a leveling kit offroad and FOR SURE if you disconnect. You will need flat flares, trimmed stock flares, or increased bump stops.
Old Feb 8, 2012 | 11:00 AM
JK.NZ's Avatar
Thanks, obviously with sway bar disconnected 33's will rub when fully articulated. I may be best to go for a 2" suspension lift to avoid rubbing and would also have the advantage of a bit more ground clearance.
Old Feb 8, 2012 | 08:38 PM
CerOf's Avatar
Even with 2" you will need bumpstops or flare modifications if the kit does not come with bumpstops.
Tera Flex leveling kit is 2" in front and 1" rear.
How Tera Flex can claim you can run a 34" tire is beyond me. A 32.25"x12" wide tire rubs like crazy disconnected with a leveling kit. I wish they would change their advertising as it is incorrect.
Old Feb 9, 2012 | 12:41 PM
skibovr6's Avatar
It was my understanding a 2010/11 Rubi can run 35s with a BB lift and wheel spacers??
Old Feb 9, 2012 | 12:55 PM
Orangeav's Avatar
You can run 35's with a bone stock suspension, that doesn't mean that you can wheel it without the potential for problems. I've seen posts of dealers slapping 35's on Jeeps with no other mod's.
I'm running 33's now with 4" BS on 16" wheels and, for a while, stock JKU X suspension. My rear tires rub the fender flares and my front tires do too when disco'd. I have since done a Rubi spring and shock transplant w/ 3/4" spacers and got a little room back but ultimately will need a proper lift or fender trim to "fix" it.
Old Feb 9, 2012 | 03:37 PM
sport43537's Avatar
I ran P255/80/17's on a 2012 JK with stock rims without any spacers and did not experience any rubbing while turning or flexing.
Old Feb 9, 2012 | 05:32 PM
flatattack's Avatar
Currently running 33x12.5's on stock suspension and 17" wheels w/4.5" back spacing. On the road or a mild trail, no problem. True offroad travel will cause rubbing in the rear and disco'ing will allow the front to rub as well. All in all, performs very well considering it basically just rolled off the dealers lot.
