BLD without ESP ?
Old Feb 8, 2012 | 01:28 AM
Paul Woodcock's Avatar
Default BLD without ESP ?
Hi guys
I am a new Jeep driver and have a 2012 Wrangler Sport with a Teraflex 2.5" lift and BFG A/T 33x12.5x15 tyres.
The car is used 75% for sand dune driving here in Dubai and 25% for running about as a 2nd car.
The ESP is pretty useless when sideways on a big dune and the ESP Off button doesnt really help, so I did the 'switch under the dash/wire cut mod.'
I am very happy with the mod. ESP and roll over protection on the dunes does not help.
What would help would be BLD..... Does anyone know if there is a way to disable the roll over and ESP but keep BLD?
I assume it is all in the one function.
Regards
Paul
The mod I did was to splice in a toggle switch into the wire, near the drivers right foot. As per:
https://www.jk-forum.com/forums/show...SP+kill+switch
Old Feb 8, 2012 | 03:44 AM
itsajeepthing91's Avatar
Follow the instructions under turn ESP off on this thread https://www.jk-forum.com/forums/show...odes-sequences
Turns esp off but keeps BLD active
Old Feb 8, 2012 | 04:25 AM
dinojeep's Avatar
He called the Jeep a car
Old Feb 8, 2012 | 04:31 AM
JKCloak's Avatar
BLD only works in 4wd, and I don't think it is linked to the ESP, There was a good video on YouTube about how it works, I will post it in a minute if I can find again
Old Feb 8, 2012 | 04:33 AM
JKCloak's Avatar
Check out this video on YouTube:
http://www.youtube.com/watch?v=K6uAK...e_gdata_player
Old Feb 8, 2012 | 04:35 AM
I had my jeep stuck in deep snow and BLD was active. I also had the kill switch mentioned wired up I hit it BLD was no longer active. I might be mistaken but I believe BLD uses ABS sensors the kill switch kills esp bas and abs therefor BLD is not active.
Old Feb 8, 2012 | 07:15 AM
JKCloak's Avatar
In 4 low ESP is completely off and BLD is supposed to work in 4 lo but I guess they could make it turn on or off whatever parts of the system they wanted to :dunno:
Old Feb 8, 2012 | 07:22 AM
Not sure exactly how it works but I do know the kill switch mod killed BLD for me I stopped using the switch and did the jeep dance to turn ESP off and BLD is active.
Old Feb 8, 2012 | 08:21 AM
JKCloak's Avatar
Good to know!!
Old Feb 8, 2012 | 01:01 PM
tslewisz's Avatar
BLD works on any driven axle, 2WD, 4HI or 4LO, and cannot be disabled except by cutting wires.
