Teraflex Monster Front Trackbar with steering stabilizer bracket
Old Feb 8, 2012 | 04:06 AM
sneck's Avatar
Default Teraflex Monster Front Trackbar with steering stabilizer bracket
So I have the teraflex track bar, and the woods steering stabilizer relocation bracket. These two just don't seem to want to play nice together. I can't seem to be able to rotate the stabilizer to a spot that it won't bind as it cycles without hitting the bolts on the track bar. I'm thinking of maybe pulling the bolts and cutting them down so there's not so much extra bolt, or maybe replacing them with something shorter. Has anyone else had this issue? Any suggestions for fixes?
Old Feb 8, 2012 | 08:55 AM
sneck's Avatar
bump. I can't be the only person who decided that their steering stabilizer doesn't deserve the beatings it gets in the stock location and who likes teraflex!
Old Feb 8, 2012 | 11:16 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Now I ran that combination with my 2008 with out any problems. Can you post a pic of how your running yours?
Old Feb 8, 2012 | 01:20 PM
sneck's Avatar
Yeah, I suppose pictures would help wouldn't they! Just went and snapped a few, tried to get a few different angles
so first, from the front
looking at it from the passenger side
and from right under it. you can see in this picture, because of how close the track bar is to the frame that I can't really pick what side the bolts go on, when I had it on the first time, the bolt was actually hitting the frame, I had to twist it. I also noticed a scratch on the steering stabilizer, I'm assuming from the bolt on the track bar
Old Feb 8, 2012 | 01:57 PM
H.I.I.K's Avatar
Oh hey why not flip the bolt so that the nut is on the other side?
Old Feb 8, 2012 | 02:03 PM
MrMadMunky's Avatar
+1 might solve your problem
Old Feb 8, 2012 | 02:04 PM
sneck's Avatar
I had tried that before, you can see on the picture from the side, the big scratch on the frame. That's why I'm thinking of just shortening the bolts
Old Feb 8, 2012 | 03:35 PM
wildandwillin's Avatar
Same here works great on my 08
Old Feb 8, 2012 | 03:50 PM
Beau's Avatar
Sneck,
I am running the monster tb, woods relocation bracket, and the stock stabilizer. I had to center the turnbuckle on the upper control arm bracket. I then pointed the turnbuckle opening towards 5 oclock if you are looking at it from the drivers side. I initially had it positioned like you do and put a nice gouge in my ss. I haven't taken it off road since I put the tb on though. So for daily driving, this works.
Old Feb 8, 2012 | 03:56 PM
Zombie Hunter's Avatar
I'd just cut the damn bolt.
