Pinch seam measurement before and after lift
Old Feb 8, 2012 | 06:36 PM
DCPGATOR's Avatar
Default Pinch seam measurement before and after lift
Havent found a thread with this information. Did anyone measure the pinch seam height before their lift? I have 17-1/8" up front and 17-7/8" in the back - stock JK X 2DR for reference.
If you did, what lift did you install and how much difference in measurements?
Old Feb 9, 2012 | 06:41 AM
LBJEEPER's Avatar
Evo did my pinch seam cut and if I remember correctly on the front of the rear pinch seam probably about 1 1/2"-2" was removed.
Old Feb 9, 2012 | 07:08 AM
jesse0376's Avatar
I would suggest bending the pinch seam over with a big hammer over cutting it!
Old Feb 9, 2012 | 07:16 AM
jdk's Avatar
jdk
He is not cutting his pinch seam, he is using it as a referance point to measure the real lift you get from a lift kit.
Old Feb 9, 2012 | 07:45 AM
DCPGATOR's Avatar
^ What he said.
I'm trying to get some reference points. At the end of the day, this will dictate if i go with the RC3.5" Series 2 w/N2.0 shocks and front LCA or the RC4.0 w/2.2 shocks and w/out CAs (both lifts are $499), but will order the CA drop bracket until i can save up some money for the entire CA package (~$1K).
