Cleaning stinky gear oil from diff overfill?
When changing my diff covers out with the SOLID Axle diff covers, apparently I put too much oil in the front one. The stinky gear oil has been puking from the breather tube and, as you know, as been drippy and nasty. It seems that the breather tube spits out on to the front left shock and all on the left side of the Jeep.
I've been to the pressure washer a few times and it's still kinda stinky. What's the best way to clean this stuff off and what's the best thing to use? I've had enough! It still drips a little when it sits in the driveway even though I changed it out almost 2 weeks ago.
Help!
Help!
Park it on level ground and pull the fill plug and let the oil drain out, if it is still over filled. The gear oil should only come to the bottom of the fill plug.This will stop it from puking out the vent. Go get your self a can or 2 of engine degreaser spray it down then pressure wash it off.
