New to me JK! Is it lifted?
Old Feb 10, 2012 | 10:22 AM
dan3jeeps's Avatar
Default New to me JK! Is it lifted?
Hi all. I recently purchased a 2007 2 door JK. Mostly stock.
The build sheet indicates that it has the heavy duty suspension with gas shocks. The springs have tags on them that seem to indicate the suspension coils are still stock jeep.
Front spring tag.
Rear spring tag
The jeep currently wears 285/70/17 tires and measures exactly 38"s from floor to bottom of fender. This jeep sits noticably higher than other stock JK's I have seen around so I am wondering if maybe this JK has a BB lift installed?
The rear looks to have some kind of an aftermarket bumpstop extension installed.
Is this a BB spacer?
Front spring.
I sure appreciate any help in determining if this JK has any lift or if the suspension is indeed all stock. I have no way to contact the previous owner to find out.
Thanks!
Old Feb 10, 2012 | 10:35 AM
Zombie Hunter's Avatar
Looks like a 2" BB. Plus added bump stops.
Old Feb 10, 2012 | 10:51 AM
FoxRacingJMC's Avatar
x2. Looks like coil spacers added between your coils. They are the plastic "puck" looking spacers at the tops of the coils
Old Feb 10, 2012 | 05:10 PM
SWRUBI's Avatar
You could tell just by looking at your swaybar angle and tell the OE angle is off indicating a lift.
Old Feb 10, 2012 | 05:21 PM
Wandell's Avatar
Loved
I agree. Looks like a typical budget boost.
Old Feb 10, 2012 | 07:24 PM
surf9's Avatar
Yeah thats a lift alright. It is similar to the one I have.
Old Feb 10, 2012 | 08:16 PM
Tonka_yellow's Avatar
First picture I could tell it was lifted. Like every said it has a small 2 inch bb
