Lockpick and Rear Monitors
Old Feb 13, 2012 | 12:40 PM
Orange-Crush's Avatar
Default Lockpick and Rear Monitors
I was thinking of going with a lockpick and getting 2 rear monitors to use along with the 430N. Will the lockpick power the monitors or do you have to hook in to something else? I am more of a fan of plug and play instead of having to splice wires.
Old Feb 13, 2012 | 12:54 PM
cppower's Avatar
You will have to run power.
The lockpick does have a constant and a switched lead that you can tap into.
Old Feb 13, 2012 | 01:06 PM
Can you tap two monitors in to one of these sources? If it can handle it, is there a power splitter cable I would need, or do you just crimp multiple power wires to the same source?
I would think the switched would be better so the monitors can't be left on accidentally.
