6" LIFT.... Which manufacture do you reccomend? post pics of your 6" lift
That will help get to the best solution to your situation. You shouldn't need to run anywhere NEAR 6" of lift for 35" tires, even with crazy flex.
Revtek 3" Coil Spring Kit 35" tires, have not trimed seam yet..
^^^This. Can you give us more info on your suspension? Which brand lift? Spacer vs. coil? Control arms? Have you trimmed your pinch seam? Any other modifications?
