Radiator fan problem, need help please
Old Feb 20, 2012 | 04:25 PM
Chris M's Avatar
Default Radiator fan problem, need help please
So I posted this morning about having some electrical issues. I unplugged the battery, waited a few minutes, and reconnected it. Problem solved...
Then I noticed that the radiator fan wasn't running although the engine was. I pushed the accelerator and it would run for a little bit and then stop. Sometimes it would start up while sitting in idle. Anybody have any idea what the deal is?
I tend to splash through puddles at every opportunity and was wondering if I had managed to get water inside the fan's housing and jacked it up somehow. Anybody have a clue what's going on, or is this just normal?
Old Feb 20, 2012 | 04:33 PM
ronjenx's Avatar
The fan comes on when the engine temp reaches 215°F, and stays on until the temp is reduced to about 195°F.
So, it's common to see the fan not running when the engine is.
Are you seeing any signs the engine is overheating, (gauge climbing beyond straight up, coolant recovery bottle over-flowing, etc.)?
Old Feb 20, 2012 | 04:39 PM
Chris M's Avatar
So it common to see the fan not running when the engine is.
No I'm not. That's why part of me suspected the intermittent fan was normal.
Old Oct 6, 2023 | 06:13 PM
shaggy_sr's Avatar
Check the wiring if it’s cut or loose pin
