JE Real Vs Rubicon Express Drive shafts?
Hey All,
Just finished my 2 Dr JK lift install and thought of ordering a set of new drive shafts.
Current new lift 3.5 ( Rubicon Express - Extreme Short arm )
Whats the difference between JE & RE drive shafts?
Do i need to order the front & rear? or Just the rear?
Below are the Drive shafts that I am intrested in ordering from Rubicon Express
Is that all i would need to insatll the shafts?
Part # Part
52301 934 RE FR CVO SHAFT 1310 JK ALL RE1883-365
52301 9000 RE FRONT T-CASE YOKE FOR RE1883-365 JK RE1810
52301 9001 RE REAR T-CASE FLANGE ADAPTER JK RE1805
52301 935 RE RR CVF SHAFT 1310 JK 2DR RE1887-240
Part # Part
Here is a pic of my JK with the RE Lift
Ok since my last post of JK here is the update so fare:
Old stock set up with only New Rims and little exterior bits:
The new update:
Warn front & rear bumpers
Micky Thompson Baja Claws 35
Rubicon Express 3.5" Lift Short Arm ( Rancho XL9000 )
4.88 Superior R&P
Borla Single Cat
Jet Chip stage 2
AEM Brute force
Mopar Tow Hitch
K.C Spot light & Windsheild brackets
OrFab Doors
Xenon Flares not installed yet as i am still thinking about painting them
Husky Floor liners
Now for the pics
The new update:
4.88 Superior R&P
Borla Single Cat
Jet Chip stage 2
AEM Brute force
Mopar Tow Hitch
OrFab Doors
Husky Floor liners
Now for the pics
Looks very nice! You will not find an after market bumper that is light. They are all heavy. If you think it is low in the back then get yourself a 1/2" or 1" teraflex spacer to get the height back.
Will i need to change the shocks? The only spacers i have found are all above 1.5" and by putting spacers i thought that would cause the coil springs stress
or am i wrong ?
Well, the spacer is just compensating for the spring being compressed...the axle will not droop further, or compress up higher, with the spacer..it just adjusts the ride height.
If the coil was too long, so full uptravel / compression could collapse the coil, and then bend the coil, then the spacer could cause damage....with the same axle travel.
Most people do not have coils that long...but, you could look at the fully compressed coil length (height), and see how much room you have...if you have a couple of inches to spare, then the spacer can't hurt.
Does anyone have a lower to upper coil bucket distance during full stuffage?
