Tire Carrier Help
Old Feb 27, 2012 | 04:05 PM
echoshotz's Avatar
Default Tire Carrier Help
Hey all. I'm looking for a tire carrier to accommodate my new rubber I'll be getting sometime this spring. I like the idea of the spare being outside rather than mounted inside the jeep (I have a 2 DR), so I'm looking for a tire carrier with or without a rear bumper. I'd like for it to be able to hold a hi-lift and maybe gerry cans/rotopax. Those aren't a must but it'd be nice. I've ruled out the or-fab due to the install and the fact that it's irreversible after drilling such a large hole. I like the Genright carrier but again it cannot hold a hi-lift from what I can tell.
Any suggestions?
Old Feb 27, 2012 | 04:20 PM
Robar's Avatar
Try OR-Fab. They have 3 versions. No fuel cans, Rotopax, or Gerry cans.
http://www.4wd.com/search.aspx?SH=QT...AnswerID=50224
Old Feb 27, 2012 | 04:36 PM
wildandwillin's Avatar
I like my LoD bumpers. I also like others lol. The LoD should fit your needs they have Jerry can mounts, rotopax mounts, powertank mounts, and a rack.
Old Feb 27, 2012 | 05:02 PM
echoshotz's Avatar
I like the LoD and may go towards that if I can't find anything else. Has anyone seen a Genright carrier with any way to mount a hi-lift? Or another carrier which can hold one?
Old Feb 27, 2012 | 05:06 PM
Wrangled's Avatar
There is always the AEV carrier, with optional 10gl fuel caddy. I believe it also accommodates a hi-lift jack.
Old Feb 27, 2012 | 06:40 PM
Weeds's Avatar
I like my Rockhard, plus it has a real trailer hitch if you need to tow. It was under $1000 from Bustabizz at 4WD. And no rattles.
Old Feb 27, 2012 | 08:09 PM
JayKay69's Avatar
I have the genright tire carrier. I talked to the guys at genright and they said they have seen guys mount them on there with fabrication. Im going to run a mount like the river raider mount that mounts it inside and out of the elements
Old Feb 27, 2012 | 08:26 PM
Sunshadw's Avatar
My Hanson carries cans and the jack, although to use, the spare must first be removed.
Old Feb 28, 2012 | 02:42 PM
echoshotz's Avatar
Does anyone have the HighRock 4x4 rear bumper and tire carrier? Pics of any bumper would help, especially if they have a hi-lift mount.
Old Feb 28, 2012 | 04:14 PM
Krynn's Avatar
TeraFlex is introducing a new tire carrier this April that looks very promising. Might be worth considering, if you're not in a hurry.
https://www.jk-forum.com/forums/show...=1#post2875154
