Testing out the new 5.38's
Old Feb 28, 2012 | 07:34 AM
Lomax-dtl's Avatar
Default Testing out the new 5.38's
I was out wheeling with my new gear and when going over a rock I noticed that the locker were not engaging. Everything is plugged up and I'm lost anyone know what it could be?
Old Feb 28, 2012 | 07:36 AM
Mr. Smiley's Avatar
Is it stock Rubin lockers? If so.. unhook the battery for a little bit then put it back together, and see if it works then. If not. Then idk :/ I don't know much about that kind of stuff.
Old Feb 28, 2012 | 07:38 AM
Lomax-dtl's Avatar
Yes it is and I tried that but no luck.
Old Feb 28, 2012 | 08:47 AM
helnbk's Avatar
Sounds like there are issues with yor plunger inside the diffs. They are very sensative and even an experienced gear installer can mess these up.
I had issues with mine when I had 5.38's installed recently.
The lockers would engage, however the lights kept flashing and not turn solid.
Had faulty plungers in mine. They are about $70 a piece.
I had my installer fix them after the 500 mile wear in period.
