Teraflex 4 inch lift LA or SA? Pics? 2 door only
Im looking to run 37's and get my jeep up higher, right now I have a 3 inch fabtech spacer lift, looks good but I want to go bigger and maybe smoother.
Is a Teraflex LA needed or will a short arm do the trick for now?
Is it possible to buy the short arm and upgrade the arms later without spending more in the future? Basically can I buy a teraflex 4 inch short arm and later make it a long arm for the cost minus what i spent of the Short arm???
Any one got pics of a Teraflex 4 inch LA or SA on a 2 door?? thanks!
Also, a longarm would be more preferable on the 2dr with the amount of lift youll get outta the tera 4in on a 2dr. You'll definately need either the TF dragflip kit or some kind of steering correction or it won't handle as it should. Been there.
