track bar reinforcement??
Old Feb 28, 2012 | 07:23 PM
monkers's Avatar
Default track bar reinforcement??
I am about to install a RK 2.5 max travel lift, and Im curious what the best way to beef up the front track bar mount is. JKS makes one that also relocates the SS, but I have another SS relo bracket, guess I could sell that one. Should I just gusset it with some flat stock? The lift kit comes with an adj front track bar. Ive heard that JKS makes another brace, but I was told it may hit something with only a 2.5 lift?? Im a little confused (happens alot) I just want to avoid the bracket failing. I see no cracks in it, but im paranoid....thanks guys
Old Feb 28, 2012 | 07:36 PM
Saharaunlmtd's Avatar
If you use some flat stock, be conscious of how your swaybar disconnects. Mine broke prior to adding discos, so when it was fixed/reinforced there was some clearance issues that had to be grinded down.
