Which axle shafts to buy???
It looks like I bent a rear axle flange on the passenger side. I will be verifying tomorrow. If that is the case I will get a new set. I am looking at Superior Evo axles. Anyone have any experience, suggestions or feedback on these it any other setup??
Thanks
BP
Thanks
BP
i've run superior and foote and both got the job done. so you know, the factory shafts aren't all that bad and, you may still end up bending the flanges on them too. with 37's, you might want to start looking at a 60
Thanks all. I'd love a 60 but it's not an option right now. If upgrading the shafts isn't going to make that much of a difference than I can buy used stockers a couple of times for the price of a new set of superiors. I was thinking that the lifetime warranty on the superior evos would cover bending it. Is that not the case??
I am wiling to pay for good parts, but not if they are only as good as the stock ones.
Thanks
BP.
Thanks
BP.
I also just recently bent my rear flanges, decided to get the superior ones and they go in tomorrow, so well see. If you look at the disclaimer the lifetime warranty does not cover bent flanges on the superiors
Good luck
