River Raider JK Dana 30 Axle Gusset Kit
Old Mar 2, 2012 | 06:01 AM
11REDJK's Avatar
Default River Raider JK Dana 30 Axle Gusset Kit
Hey all, anyone on here used this? Will this really strengthen a D30?
Opinions?
Old Mar 2, 2012 | 06:04 AM
wayoflife's Avatar
JK-Forum Founder
if you are referring to gussets that reinforce the axle c's, they'll all do the same job and yes, they will help prevent the bending of the c's.
Old Mar 2, 2012 | 06:08 AM
11REDJK's Avatar
Is it something that is worth doing? Moderate 4 wheeling, but not looking to replace my front axle unless I break it..
Thanks
Old Mar 2, 2012 | 06:11 AM
FoxRacingJMC's Avatar
Thanks
It is cheap insurane to help prevent them from bending. Anything can happen on the trail, all depending on how you wheel and what you call "moderate or hard wheeling". Everyones idea of wheeling is different....
Old Mar 2, 2012 | 06:19 AM
11REDJK's Avatar
Well, I live in Florida...the most extreme wheeling I would see is probably some of the obstacles at Jeep Beach..It does get a little rougher up around Ocala, but I dont get up that way often. Mostly MUD, and small hills here.
Will this help strengthen for 37 inch tires? Sorry, my TJ has D44 front and back so first time I am dealing with this
Thanks
Old Mar 2, 2012 | 06:25 AM
wayoflife's Avatar
JK-Forum Founder
Thanks
if you plan on running larger than stock tires, yes, it's definitely worth doing. the c's are weak and prone to bending and that will give your wheels camber. before someone comes on here and recommends it, you DON'T need to sleeve your axle.
Old Mar 2, 2012 | 06:29 AM
you don't as WOL said, that and no need to "truss" the axle tube either for that matter - being that a truss is an alternate way to strengthen the tubes on the outside as supposed to sleeves for the inside of the tubes
Old Mar 2, 2012 | 09:48 AM
11REDJK's Avatar
Thanks guys, much appreciate your assistance
