Rear sway bars with 3" lift..??? help please...
Old Mar 2, 2012 | 02:31 PM
MotiCross's Avatar
Default Rear sway bars with 3" lift..??? help please...
I have a 3" lift.... i think... and my rear sway bars are still stock. should i change them and to what ??
Thanks!
Old Mar 2, 2012 | 02:33 PM
MotiCross's Avatar
would these do the trick?
http://northridge4x4.com/proddetail....AYBAR-LINKS-JK
Old Mar 2, 2012 | 02:36 PM
brink2177's Avatar
The rear swaybar should be level with the ground. If yours is angled down, then you should add some adjustable endlinks like the ones you asked about in order to bring it back up to the correct angle.
Old Mar 2, 2012 | 02:37 PM
MotiCross's Avatar
Yea they are angled WAYYYYY down ....
Maybe these:
http://northridge4x4.com/proddetail....od=CE-9807RSBX
Old Mar 2, 2012 | 02:42 PM
brink2177's Avatar
Either one will work just fine. I currently have the JKS ones, but I think they are all pretty much the same. Good luck with getting it back to normal!
Old Mar 2, 2012 | 02:47 PM
MotiCross's Avatar
Should i just get the JKS quicker disco or no need...? i dont think i would ever disconnect the rear... but who knows
Old Mar 2, 2012 | 02:50 PM
brink2177's Avatar
They are not needed on the rear... only the front.
These are the JKS' I was talking about:
http://www.northridge4x4.com/proddet...?prod=JKS-2943
Old Mar 2, 2012 | 02:54 PM
MotiCross's Avatar
Those look good. perfect. ii guess i'm ordering those
Old Mar 2, 2012 | 03:05 PM
MotiCross's Avatar
Done deal, thanks again.
Just ordered on eBay for $76 and free shipping.
Can't wait
Old Mar 2, 2012 | 03:08 PM
brink2177's Avatar
No problem. Install is easy, so you shouldn't have any issues... just need to cut the links down to the correct length. Good luck with it!
