Changing out trac bar and LCA bolts.
I just got my new bolts from Northridge and want to get them changed out this week. Can I replace them with the tires on the ground or do I need to lift it to take pressure off?
No need to remove the tires. Do one arm at a time and once done bounce the front to help settle it before torqueing. Support the axle when doing the track bar with a jack.
Sent from my HTC Liberty using Tapatalk
If at all possible, the nut should be the side you tighten from not the bolt head. As the bolt can bind against things and throw of your tourqe reading.
I'm not an expert, I just assemble municipal water systems for a living and happen to know a thing or two about tigthening bolts.....
