AEV Drop Bracket BS
Old Mar 3, 2012 | 01:47 PM
SH0RTBUS's Avatar
Has anyone successfully removed the passenger side upper control arm bolt by prying the exhaust out of the way as instructed in the AEV drop bracket instructions? I read the instructions before I started and even went and bought a pry bar. Now I see most people just cut the bolt and replace it. I don't have that luxury as my Jeep is now disassembled so I have no way to get to the hardware store. F@$k AEV. After this ordeal I'll never purchase another product from them.
Old Mar 3, 2012 | 02:03 PM
mkjeep's Avatar
Hmm, You could cut the bolt, install your arms minus the passenger side upper CA and therefore it becomes a teporary 3link frt. Drive to the store, install bolt
Old Mar 3, 2012 | 04:56 PM
SH0RTBUS's Avatar
I found a smaller diameter bolt and nut so I could limp to the store. What a pain in the ass. AEV should update their instructions to cut the bolt and they should include a replacement. There was no way in hell that bolt was coming out by simply prying the exhaust out of the way.
Old Mar 3, 2012 | 05:10 PM
Saharaunlmtd's Avatar
I've read about needing to cut that bolt in many threads on here.
AEV should include a replacement with the brackets.
Old Mar 3, 2012 | 06:09 PM
CruSHeDJkUR's Avatar
It possible, I've done it.
Didnt cut the bolt.
Used a rachet strap and a floor jack to pry the exhaust out of the way. It was a bitch should cut the bolt but it was at night and I wanted it done.
Old Mar 3, 2012 | 06:14 PM
TAIL RATED's Avatar
have helped two buds pry that over and get the bolt out on their rigs. ratchet strap and/ or prybar/ and took all of 5 minutes both times once we figured out how to do it. man up, and move it over.
Old Mar 3, 2012 | 06:46 PM
JKAbomb's Avatar
any difference in handling after installing. i have mine sitting in the garage waitng to install.
Old Mar 3, 2012 | 06:58 PM
Big difference. You will be very happy.
Old Mar 3, 2012 | 07:08 PM
theZombie's Avatar
Would i expect to have this problem on a 2012?
Old Mar 3, 2012 | 07:35 PM
rays0852's Avatar
I bought the same kit but from rough Country...included the bolt and I paid $10 less.
Not knocking AEV's stuff, but I feel awesome right now.
