37in toyos and bumpsteer!
I'm having some bumpsteer issues on my 2 door. It drives fine on flat ground. I have a pr44 unlimited. My Castor is set at 6.2 on driver and 6.7 on passenger. I have rockkrawlers flipped drag link and there rasied trac bar bracket welded to my axle. I'm running around 25psi in the tires. Everytime I go over a bump it will wander some in the road and I will have to correct it. Is it the tires? Any advice would be helpful.
Make sure your draglink and track bar are at close to the same angle. If you had a drop pitman arm prior to the draglink flip put the stock one back on. I had to remove drop pitman arm when flipping my draglink. Hope this helps.
Originally Posted by Vinson Clark
Im running a rockkrawler trac bar,trac bar bracket. My drag link and trac bar are at the same angle. I'm running the 3.5 x factor kit the only thing stock is the tie rod.
Im running a PR44 unlimited it has castor built into it. Its not bad but everytime i hit a bump at a higher speed it will wonder just a little bit and i have to correct it. I can drive it with one finger on the wheel going down the highway though.
I see your running 37in toyos as well do you experience and noticeable steering changes over your stock setup?
