Rear Driveshaft Needed on a 2012 2 door JK Rubi with 2.5-3.5" lift?
Old Mar 4, 2012 | 08:07 PM
silversurfer575's Avatar
Default Rear Driveshaft Needed on a 2012 2 door JK Rubi with 2.5-3.5" lift?
Greetings fellow Jeepsters
I have a 2012 2 door JK Rubi. Getting ready to start to map out the lift items I need. Plan to go with 35's, flat fenders, and 2.5-3.5" lift. Most likely going with brand: RK.
I know that with any lift beyond 2", Im looking at a new front driveshaft. What about the rear? At what point do I need to consider replacing that one as well?
Thanks in advance for your answers.
Old Mar 4, 2012 | 08:20 PM
FlameRedJK's Avatar
I've been wondering the same with my 2012 JKU.
Subscribed.
Old Mar 4, 2012 | 08:29 PM
MTG's Avatar
MTG
Edit: can't help you with 2 door.
Old Mar 4, 2012 | 08:32 PM
rays0852's Avatar
I'm no expert, but I believe its when you go above 3.5".
I went with a 2.5" and I can tell you that any JK lift you will need to do the front DS and reposition your evap skid over 2" to the driver side so you do not rip your boot off your rear DS.
The rear DS angle is not bad at all on my 2.5" lift. I can see getting another inch or so out of it, but anything over that I would personally not feel comfortable with the stocker.
Old Mar 4, 2012 | 08:34 PM
joe002's Avatar
Originally Posted by dojohnso
...I know that with any lift beyond 2", Im looking at a new front driveshaft. What about the rear? At what point do I need to consider replacing that one as well?...
I have an '08 2 door with a TF 2.5" lift and the stock front and rear shafts.
Run the stockers. If/when you see grease coming out of the CV joints then you'll know you need to replace them.
Old Mar 4, 2012 | 09:57 PM
Thanks all for your replies.
I still dont see a definitive answer. I got a "not sure" type answer as well as a "run stockers until they fail"
I want to be proactive, but dont want to buy a rear driveshaft unless its necessary.
Thanks in advance for more responses.
Old Mar 5, 2012 | 03:22 AM
lostskiier's Avatar
No you don't NEED a new DS. I have the 3.5" AEV Dual Sport SC lift and I can tell you that a new DS is not required....Final Answer.
Old Mar 5, 2012 | 03:31 AM
Dr. Satan's Avatar
That's the thing, It's not NECESSARY until the stocker fails. No one here can tell you if and when it will happen. The higher the lift you have the higher the odds of failure. The harder you wheel the higher the odds of failure.
Old Mar 5, 2012 | 04:01 AM
lostskiier's Avatar
Yes, eventually you MAY need a new DS. Everything wears out, someday you'll need a new Alternator, Battery, Tires, and so on and so forth, But you do NOT need a new DS if you plan on keeping the lift below 3.5".
Old Mar 5, 2012 | 04:07 AM
JoeGunner's Avatar
You'll have all the clearance you need.
