Auto Trans Pan Leak
Old Mar 4, 2012 | 08:09 PM
Mr.ZAP's Avatar
Default Auto Trans Pan Leak
Howdy guys, I've got a very slow but persistent leak coming from the tranny pan. It isn't much, looks like a lip of the pan got bent a very small amount which shifted the sealant around and caused a little gap. Should I take it to a shop and get them to drop the pan and the whole nine yards, or just continue to monitor it and add fluid as needed? I have never had any issues with my tranny and when I got the fluid changed probably 20,000 miles ago they said it came out nice and clear. Any help is appreciated.
Old Mar 4, 2012 | 08:10 PM
Mr.ZAP's Avatar
Also, it must be noted that the drive shaft HAS NOT come into contact with the pan.
Old Mar 4, 2012 | 08:37 PM
ronjenx's Avatar
If it's leaking enough that you have to keep an eye on it and periodically add fluid, I recommend you fix it immediately.
I also recommend you get a new pan from the dealer, (about $10), and have a drain plug welded into it, so it will be ready to install when you pull the leaking pan.
Old Mar 4, 2012 | 09:31 PM
Mr.ZAP's Avatar
It leaves about a quarter-sized spot of ATF overnight.
