Lifts and swaybars
Just installed OME spring lift and have noticed my swaybars do not have allot of room for travel. It looks as if I flex too far that they could rotate back and end up breaking or bending.
So my questions would be.....am I worrying about nothing?.....At what height of lift do you need longer swaybars?......If I need new ones, all I can find are links for 3' and above lift, would they be too long?
Thanks for any help...
http://www.currieenterprises.com/ces...t.aspx?id=2853
http://www.currieenterprises.com/ces...t.aspx?id=2875
Just make them longer than the oem ones by the amount the ome lift lifts it.
The easy way is to disconnect the lower parts, let it hang, and set the new length for the new, further, distance. (The distance below where the stock one hung, to the place you NEED it to reach)
