REAR sway for 3" lift???
Old Mar 5, 2012 | 01:16 PM
MotiCross's Avatar
Default REAR sway for 3" lift???
Any suggestions? i have the stock sways and i need an upgrade...
Thanks
Old Mar 5, 2012 | 01:46 PM
Mr. Smiley's Avatar
Teraflex, RK, JKS Currie all make goo products
Old Mar 5, 2012 | 01:52 PM
MotiCross's Avatar
I looked into all of those but they all to say to go along with thier lifts... does that matter...?
Old Mar 5, 2012 | 02:19 PM
TeraFlex's Avatar
Sponsoring Manufacturer
You can run the TeraFlex with just about any normal lift.
http://www.teraflex.biz/jk-rear-trai...-0-3-lift.html
Old Mar 5, 2012 | 02:42 PM
Mr. Smiley's Avatar
Nope. It's a sway bar. Should work for almost any lift, besides maybe a LA or Coil over set up so yes. You will be fine.
Old Mar 5, 2012 | 02:45 PM
Tvernon's Avatar
Teraflex makes a great product, they also do one that is "disconnected" in the rear. It's much more pricey, but looks sorta interesting. However, I have never seen them in action so I cant speak to performance.
The Currie anti-rock version of the same product however, I can speak too. Jeeps with them are much more sure footed in off-camber situations than they are with the stock sway bars. It opperates off of a spline system which forces one tire down when one tire goes up, insuring that you maximize traction to the tire with less weight. I've seen this product do wonders to rock crawling JK's.
All the products you mentioned though are quality. They all will produce similar results and function in a similar capacity. They all should be compatible with different lifts as well.
Good luck,
Tyler
Old Mar 5, 2012 | 03:22 PM
TeraFlex's Avatar
Good luck,
Tyler
Sorry none of our rear actually disconnect. It's the fronts that will do that, thanks.
Old Mar 5, 2012 | 03:25 PM
Tvernon's Avatar
I obviously got the two confused.
Thanks for the correction.
Old Mar 5, 2012 | 03:28 PM
MotiCross's Avatar
I already have these in the back... i just need the sways. Thanks again though!
http://www.teraflex.biz/jk-wrangler-...-flexarms.html
Old Mar 5, 2012 | 03:34 PM
Absolute's Avatar
The benefit of the TeraFlex Sway Bar over the Currie is there are multiple link holes on the arms so you can adjust stiffness/softness of the sway bar. That's a nice option to have.
