Lift question, adding Rubi springs
From: East Texas or Shreveport depending on the day
I've got a 4dr X with a 2.5 BB, if I added some springs from a Rubicon, how much lift would it give me? Would it change anything enough to cause angle problems with the drive train? I also have a 3/4" spacer in the front for leveling and the winch. I'm looking to lift it a tad more so that I can run 35's when I re gear.
Any experience with this? Thanks.
Chances are you will not get any lift. Rubi springs are the same as you can get on a sahara and the x. It just depends on what set up you have. If you did get any lift it would probably only be a 1/2 gain at best. More work than benefit.
