1310 vs 1350 driveshaft
Old Mar 20, 2012 | 12:34 PM
Moraespedro's Avatar
Default 1310 vs 1350 driveshaft
Ouldn't find the info...
1310 hold ut to 35s? I wish to buy JE Reels Hd drive shaft... Just dont know if 1310 or 1350...
My trails are mostly mud, minor rock crawling... Now with 35s, but soon 37s...
Thanks
Old Mar 26, 2012 | 02:53 PM
Bump... bump... bump... bump...
Old Mar 26, 2012 | 02:56 PM
TexasT's Avatar
From what you are describing the 1310 should be just fine
Old Mar 26, 2012 | 03:47 PM
Prime8's Avatar
What front axle do you have and have you made any mods to it yet?
Old Mar 26, 2012 | 03:53 PM
Prime8's Avatar
The reason being... I was contemplating the same thing about a month ago. The advice I got was that its better to break a driveshaft component when your wheeling than an axle component. So unless you have a loaded Prorock 44 or a D60 up front, I'd say that the 1310 should be plenty. The 1350 would be overkill and TOO strong. That's why I went with the Coast 1310 in the front, which I'll be installing this weekend!
Old Mar 26, 2012 | 05:37 PM
69mach1's Avatar
Cool
Ditto Prime8
I was told the same thing, best to have a weak point that is easier to fix. I installed the Coast 1310 driveshaft and am very happy with it.
Old Mar 26, 2012 | 06:37 PM
dinojeep's Avatar
I third that. And I'll be ordering a 1310 soon and plan to run 37 s with it
Old Mar 26, 2012 | 07:04 PM
chris.george's Avatar
Can you expand on "too strong"?
Old Mar 26, 2012 | 07:14 PM
sa29560's Avatar
As was said, you want that drive line u joint to be your weak spot. Better than the ring or pinion taking the force of a break, versus a twenty dollar u joint.
Old Mar 27, 2012 | 06:30 AM
BPMOTO505's Avatar
I ran 1310's with 37's for a couple years with no problems at all. I do hard rock crawling a few times a year.
