Control Arms
Old Mar 22, 2012 | 05:17 PM
Tkautos@verizon.net's Avatar
Default Control Arms
I am getting ready to install my Rough Country 4" lift tomorrow afternoon and I was wondering before I begin, I am going to use the cam bolts that came with the lift on the front. However, one day I would like to change over to adjustable control arms and an adjustable trackbar. How do you fill in the "notch" that you have to knock out?
Old Mar 22, 2012 | 05:28 PM
Mr. Smiley's Avatar
I'm pretty sure you have to weld a washer onto the CA mount.. But I'm not 100% sure
Old Mar 22, 2012 | 05:31 PM
sempermarc's Avatar
The front lower control arms are a much better choice! Spent the extra cash and do it right. You will not regret it.
Old Mar 22, 2012 | 06:47 PM
What would happen if I just left the control arms "as is"? In other words, what would happen if I didn't install the cam bolts or install new control arms?
I appreciate the feedback.
Old Mar 22, 2012 | 06:52 PM
JK-Tex's Avatar
Extremely flighty steering due to bad caster. With a 4" lift, you've got to do something about the control arms.
Old Mar 22, 2012 | 06:58 PM
nthinuf's Avatar
As you lift higher with stock arms, the axles start tilting, which raises the pinion and lowers the caster. Lower caster causes flighty handling/wandering.
Some people say it isn't 'that' bad, and they spend the arm money on other components. I personally hated the handing over 3" with stock arms.
Drive it after the lift and see what you think. If you absolutely can not afford arms, you can always go back and install the cams - and then deal with the welding later.
Old Mar 22, 2012 | 08:13 PM
Topkicker1's Avatar
I had bad flighty steering with my RK 2.5 lift. It came with adj track bar. I ordered the RK adj LCA's and dialed my castor back to stock spec. Drive's great. Love the shape of the LCA's for better clearance also. Win win.
Old Mar 22, 2012 | 09:15 PM
catahoula's Avatar
From what I've read on this forum the arms are the way to go. I will be installing when I get my lift, but I am going 2.5" and have spoke to a few on hear mentioning I might not need them due to height. Best to drive then decide in my case. Search forum on cam bolts it just might change your decision to use them.
Old Mar 22, 2012 | 10:36 PM
pcmasten's Avatar
Veteran: Marine Corp
Is 6 degree's on the caster still the optimal for a 3" lift? Everyone seems to have a different idea here. I had mine adjusted and the best they could do was 5.6 due to the pinion angle.
Old Mar 23, 2012 | 03:47 AM
For the time being, could I just use the control arm relocation kit from Rough Country?
