How Long are your Rock Krawler Links?
Old Mar 25, 2012 | 09:42 AM
jason0341's Avatar
Default How Long are your Rock Krawler Links?
Hey guys I am currently running a Teraflex 2.5 Coil lift with a 1" TF spacer on top.
I ordered some 3-4" Rock Krawler front sway bar discos and I received these. Do the lengths look right? The main middle bar is 8" long, and as you can see in the picture I can not shorten them up anymore. My sway bar will be angled upwards too much if I install the ones I have. I bought them through the 4wd.com rep here on the forum but they were drop shipped from Rock Krawler directly.
Old Mar 25, 2012 | 09:49 AM
wayoflife's Avatar
JK-Forum Founder
your sway bar will sit up high but, it's really not a problem. in fact, depending on how much droop you have, it's recommend that you install longer links to help prevent you from over extending them and bending them on the tie rod. i would install these as is.
Old Mar 25, 2012 | 11:23 AM
jason0341's Avatar
I was thinking about that but if I am using them as quick discos, no rubicon here, shouldn't my sway bar be parallel to the ground or no? Thanks for the help
Old Mar 25, 2012 | 02:52 PM
tslewisz's Avatar
Level is the general guideline. I'd probably shorten them.
Old Mar 25, 2012 | 04:52 PM
jason0341's Avatar
I went ahead and installed them and they look fine. I also had some help from my 14 month old little girl. She wanted to be on daddy's lap the whole time
Old Mar 26, 2012 | 06:44 AM
Rock Krawler Suspension's Avatar
Former Vendor
Our 2.5" ones have a 7" tall center pin and it is as simple as swapping the pins if you ever feel you need a shorter one!
RK
