Rock Hard "Straight Across Rear Bar" for Harnesses?
Old Mar 28, 2012 | 11:44 PM
MYBLUEJK's Avatar
Default Rock Hard "Straight Across Rear Bar" for Harnesses?
I have purchased Mastercraft Harnesses and want to run them in my 2010 2 Door JK. I obviously need some sort of bar to fit the harnesses to behind the front seats. I have been looking for a bolt on rear bar and all i have found is the "Rock Hard Straight Across Rear Bar". I have found photos of this bar being used for harnesses, but have also found photos of it being used for a sports cage like system on the stock roll cage.
Does anyone know if either of these uses would be "correct" or "incorrect"?
Would using this "Straight Across Rear Bar" be a bad idea to run harnesses off of?
Any experience helps!
Thanks
Max
Old Mar 29, 2012 | 02:56 AM
sneck's Avatar
I know when I had the urge to run some 5 point harness's, I found that I would need the rockhard bar to properly install them. I might search around for threads on 5-point harness and see what turns up
Old Mar 29, 2012 | 03:07 AM
RANGER666's Avatar
As long as the shoulder straps sit higher than the shoulders you will be fine. If not then the spine compresses during impact.
