Is this going to be needed?
Old Mar 29, 2012 | 09:14 AM
GunDude's Avatar
Default Is this going to be needed?
O.K., I have front and rear Coast drive shafts, that are going to be installed next summer with new gears! I am thinking of going ahead and adding the new rear TeraFlex upper control arms, coil spring wedges and coil spring retainers, then rotate the pinion inline with the stock DS. I am wanting to know if I am going to have a binding problem with the adj. JKS rear track bar binding in the axle mount and will I need to add a JKS trackbar bracket?
I have around 3.25" of lift. Those with 3"+ of lift on a 2 dr, can you post pics of your rear axle trackbar in the bracket to set if it is binding!
Old Mar 29, 2012 | 06:01 PM
JK-Rubi's Avatar
My lift is very close to or just over 3" on my 2DR, and I'm mulling over a bracket purchase to correct for roll center. I feel just a tad bit of rear steer and think a new bracket (that raises the TB a bit) would help, as well as, beef up the mount at the axle. Maybe others can chime in with more definitive advice.
