Help rear tires close to pinch seam
Old Apr 1, 2012 | 01:28 PM
silverbackjk's Avatar
Default Help rear tires close to pinch seam
Hey guys i just added 35 in nitto trail grapplers on my jeep it has a 2 in lift and since adding the 35's my rear tires are inly 1in from my pinch seam. What are my options i am afraid at full flex my tire will hit the seam and rock rails. What should i do to fix this?
Old Apr 1, 2012 | 01:30 PM
Lucas's Avatar
Trim it.
Old Apr 1, 2012 | 01:31 PM
jim hensley's Avatar
Search for trimming your pinch seem in the search function. Plenty of info on how to. Just need a saws all or grinder. Not real hard.
Old Apr 1, 2012 | 01:35 PM
thanks guys i will try this. but will need to get new rock rails.
Old Apr 1, 2012 | 01:47 PM
TRAUMAhead's Avatar
What rock rails? If they're Rubicon sliders, you can chop those down too.
Old Apr 1, 2012 | 02:41 PM
They are mopar rails and have a second rail welded to them
Old Apr 1, 2012 | 02:57 PM
these are the rock rails i have weld is to close to end to cut i think.
http://www.quadratec.com/products/12112_223_07.htm
Old Apr 1, 2012 | 02:58 PM
kfxbryan's Avatar
I wonder why Jeep thought this pinch seam should go back this far?
Old Apr 1, 2012 | 04:06 PM
EzK's Avatar
EzK
I doubt 35s will hit. Test it before trimming anything.
Old Apr 1, 2012 | 04:55 PM
littlewhite's Avatar
Cut the crap out of it! When I put my 37's on, I cut my stock sliders when I had them as well. I had to cut it so much I filled the open space with gasket maker.
